Hi all,
Im having a little problem trying to setup eyefinity, I'm using an XFX R9 270X 2GB GDDR5 Dual DVI HDMI Dual Mini DisplayPort PCI-E Graphics Card and three 17" dell monitors (vga only) I have them connected via mini display port to vga adapter and the other two connected via DVI to vga adapters, but the problem i'm having is that the bottom DVI connection on the gfx card doesn't seem to work (that monitor doesn't show up in the configuration panel on the pc) now all the monitors work as I have switched them around on the gfx card, so I'm wondering if its the card or is it something to do with eyefinity i.e. you can only run one DVI to vga adapter?
