Eyefinity mode adjusted according to how many monitors turned on - does such a program exist?
17 Apr 2006
3rd rock...
Hey guys hows it goin :cool:
So...Im really enjoying my 3-screen Eyefinity setup powered by a Powercolor HD5850. I got a question though and this is probably like wishing for the moon but here goes...
I got Eyefinity mainly to play FSX on and for that its brilliant. Its also awesome on games like Stalker SOC, Fallout 3 etc.
But this 3-screen stuff aint my cup of tea when Im just using Windows - browsing the net, typing docs, watching YouTube etc. For stuff like this I prefer to use one screen and a max of two perhaps keeping the third turned off.
Right now to do all this I have to go through the Catalyst app enaling/disabling groups blah blah blah its so clunky.
So I keep 3-screen Eyefinity mode on permanently. The HydraGrid is very handy cuz it lets me use just the center screen for Opera and other apps like my Open Office stuff. However even with the outer two screens physically turned off Eyefinity mode is of course still active.
So the Start menu is on the left screen (which is turned off)...little annoyances like that.
Is there a program out there that can sit in the background and:
1. Monitor which displays are turned on
2. Depending on this it adjusts Eyefinity accordingly
So you turn on your PC and only turn on the center screen - Eyefinity wont be enabled.
As soon as you turn on the far right screen 2-screen Eyefintiy is enabled...and if u finally hit the power button for the left screen full triple-screen Eyefinity is activated.
Or am I missing something stupidly obvious in Catalyst :eek:
This does work as standard with cat drivers already. I can turn the left and right displays off and the centre monitor changes the desktop to 1920x1080. Turning the side monitors back on automatically changes desktop back to eyefinity.
I have found the resized desktop only shows on one of the monitor outputs. Keeping only one of the other monitors turned on either shows no task bar or 1/3 of the original eyefinity display.
Make the display that shows the smaller desktop your centre monitor and you are good to go.
Not been able to get it to work with just 2 monitors turned on. So its either 1 or 3 displays.
Oh cool I need to check this out. When you do this (turning only center monitor) does it auto-adjust the taskbar so your Start menu & system tray are all on the center screen? Thanks for the reply, off to have a fiddle with Catalyst :)
Yes, with only the centre monitor on the desktop changes to 1920x1080 and the task bar is re-sized too. The start menu, the system tray, and clock all show up on the centre screen. Its just a case of finding the correct monitor output to make the centre screen.
