Hi,
I've just added 2 x BenQ XL2420T monitors to my Dell U2410, (until I can afford another BenQ so they're all the same) and set up Eyefinity in portrait mode (3240 x 1920) until I can clear enough space to try landscape.
It took a while to get some games going in the right resolution and while it looks impressive, (a bit like having a 42"+ TV on my desk), I'm really struggling with the bezels. They're not particularly big on their own, in fact the U2410 and XL2420T bezels are a similar size all the way around, it's just that when they're together and double the thickness, it cuts out quite a chunk of the viewing area.
I've done the bezel adjustment through CCC, but this now means that I can't read a lot of menus or text in games or in Windows. For example, I couldn't read information on a web page where the text was placed in the middle of the screen because the left and right margins of the text were under the bezels between the middle screen and the two outside ones.
Also, I noticed that the viewing angle of the BenQ is really bad when viewing from below the screen, (the one on the right in portrait mode). It's so bad that I have to sit in front of it to see the screen properly. Viewing from above, (or the screen on the left in portrait mode) is nowhere near as bad.
I know that Nvidia have a hotkey that will take off bezel adjustment and place text and menus either side of the bezel, does anyone know if the same can be done with CCC?
It took ages to decide whether to go for a multi-monitor setup or whether to upgrade my 5870 to a GTX 680, but as the 4GB models aren't available yet, I went for the monitors instead and I'm wondering whether I've done the right thing....
I'll try it in landscape mode tonight to see if it looks any better, but does it take time to get used a multi-monitor setup? I'm trying not to notice the bezels, but at around 4cm thick when they're together and not being able to see what's behind them in normal use is making it difficult.
Any suggestions or comments from other Eyefinity / multi-monitor users would be greatly appreciated. Thanks!
