Eyefinity not working
Don
18 Oct 2002
Wargrave, UK
I have 3 of these: http://www.overclockers.co.uk/showproduct.php?prodid=MO-034-BQ&groupid=17&catid=949&subcat=
1 of these: http://www.overclockers.co.uk/showproduct.php?prodid=GX-250-SP&groupid=701&catid=1915&subcat=1577
And a PowerColor 6850.
I can't for the life of me get Eyefinity to work. The 2 displays on the DVI ports work fine but the display port connected screen is having none of it. I can't get any kind of a picture at all. If I un plug it, it says: "No signal detected", then goes in to power save mode when connected to the DP adaptor.
Are there any tricks to getting this working?
The Sapphire Active DP to SL-DVI-D Adapter Cable are hit & miss.
You want A BizLink DisplayPort to DVI-D Dual Link Adapter , ACTIVE , Powered by USB Port.
And they are all made by BizLink but get re-branded allot.
OK, fixed it.
I was being a moron. I didn't realise I had to push the display port thingie in rather hard and get it to lock in place. I was just being too gentle.
Works like a goodun now.
OK, fixed it.
I did the exact same thing with my 6950 yesterday...
Clicky
