- 10 Jan 2012
Started trying out eyefinity on my sapphire 6870 flex today. There is so many options! I'm sticking with using 3 monitors for now as this flex edition card supports 3 without any adapters unlike standard ones which require display port adapters.
The thing is, I don't have 3 of the same size monitors. I have
1x 1440x900
1x 1280x1024
2x 1680x1050
1x 1920x1080
Eyefinity is capped at the resolution of the lowest monitor so if I use the 1280x1024 I won't get full resolution on any of the other monitors so its slightly blurry. Having eyefinity enabled increased the idle temerpature of the card from low 30's to low-mid 40's while using default fan speed (33 percent) These are the eyefinity resolutions I have tried so far
3840x1024
5040x1050
and my favourite
3072x1280
What an odd resolution you must be thinking, achieved this by having my 3 monitors rotated. It's actually really good to use, not too wide for your field of view like regular eyefinity. Heres two screenshots of it.
Uploaded with ImageShack.us
1x 1440x900
1x 1280x1024
2x 1680x1050
1x 1920x1080
3840x1024
5040x1050
and my favourite
3072x1280
