eyefinity problem
3 Aug 2010
first of i have posted this in the general hardware section because i don't know if the problem is my gfx card monitors and adapters im using or the cables.
basically my problem is that everytime i use eyefinity i have to spend anything from 5 mins-20 mins to try and get it working properly.
what happens is 2 of the screens will be fine but then if i try and do anything on the third one it will go all flickery and lines with appear and then and then go away when not on that monitor. this is usually on my monitor that i am using hdmi with, if i then change my preferred monitor it will start happening on my 2 other ones not the hdmi one. normally to sort it out i have to keep disabling my monitors, extending them, creating groups, disabling groups, and i fixed it by changing my oc on the gpu once before.
the moniters i am using are
samsung syncmaster 172v 17inch
a umc 19inch monitor, not sure which model
acer p193w 19 inch
and the adapters/ cables i am using are
hdmi
dvi to vga
display port to vga
it has got to the point where i am fed up of doing this everytime i want to use eyefinity if anyone could help me i would be soo happy, also if anyone requires a video i will make one and upload it to youtube:(
