Eyefinity problem
8 Dec 2004
Hampshire
So I have 2 x 280Xs in crossfire. And want to enable Eyefinity.
2 Monitors pick up no problem. The third does not.
The working monitors are plugged into Card #1 DP port and HDMi port.
The third monitor is plugged into another HDMI port in Card #2.
What am I doing wrong?
According to the Eyefinity FAQ on AMD's website all three monitors must be connected to the primary card if using Crossfire.
Really? Theres no way to do it via the second gfx card? I just disbled crossfire and all monitors are working fine now... its weird.
Ok so all 3 monitors are being detected but I cant get the blasted thing to go configure all 3 monitors for eyefinity...
E: So I have each monitor plugged into the same GFX card. One via DP, one via HDMI and the other via DVI.
2 monitors are displaying, but it refuses to display a third. And I have no idea why this is.
So I heard about these active DP adaptors but I was told these are no longer necessary since the R9s have this inbuilt or something?
Which monitor is DP adapter on? I had only detection of 2 screens untill i put screen 1 top DVI
2 bottom DVI
3 DP adapter.
Had DP adatper in 2 when it wasn't working.
Sorry dont understand your question bud?
Basically this is the situation.
DVI -> HDMI (using a DVI to HDMI convertor)
DP -> HDMI (Just a cable with DP on one end and HDMI on the other)
HDMI -> HDMI
E: Just to clarify I do not have DP adaptor or anything like that. Just purely cables. I believe that the 280Xs dont need an Active DP adaptor?
HDMI -> HDMI
Soory thought you had adapter. Is the DP the 3rd monitor?
Well the DP is in one of the monitors, does it matter which monitor?
E: Sorry do you mean does the Monitor HAVE DP itself?
To be clear all monitors do not have DVI or DP. Just HDMI inputs.
If you're crossfiring, only the ports on card 1 are active, all ports on card 2 are disabled. If you disable crossfire, the ports on card 2 can be used, but you can't use Eyefinity or use the GPU grunt of both cards on one game.
HDMI, DVI and VGA each require a clock signal, Displayport does not. 5xxx - 7xxx series AMD cards can only produce 2 clock signals. Using a passive connector, such as your DP-HDMI cable, will force the card to send a clock signal through the cable, which is why you can only get 2 screens to work at once. You need an Active Displayport to HDMI adapter, as this produces the clock signal so the GPU itself doesn't have to.
FLEX models of 5xxx-7xxx series cards have 3 clock generators, and the new R9 290 and 290X can support 3 screens on DVI/HDMI, but your 280X is a rebranded 7970, so you WILL need an active adapter to run your 3rd screen. Something like Startech's DP2HDS would be perfect, but pricey. Would be cheaper to go Active DP to DVI, then use a DVI to HDMI cable, but can't guarantee that'll work.
Thanks for the explanation. Bit of a pain but there you go.
I ordered this.
LINK REMOVED BY ME!
Will it do the job?
