Eyefinity question
20 Jul 2007
Preston
Im currently running eyefinity over 3 monitors but if I maximise a program it covers all 3 monitors. Is it possible to set it up so I can maximise a program on only 1 monitor for example.
If you want the behaviour you describe then you’ll need to disable Eyefinity and configure the additional screens using the normal extended desktop model.
Set up a few profiles with hotkeys under CCC. For example I have CTRL-ALT-1 for one montitor only, CTRL-ALT-3 for 3 monitor extended and CTRL-ALT-E for eyefinity. Works well
