eyefinity quick question...
7 Jun 2003
Gloucestershire
3 x monitors with HDMI inputs
2 x HD7950s with 2 x mini-dp, 1 x hdmi, 1 x DVI outputs on
am i right in thinking that so long as one monitor has a mini-dp to hdmi adaptor it doesn't matter what else i use in order to use eyefinity?
I assume it's still the case that you must use a display port output in an eyefinity setup, but do i need to use dp + hdmi + dvi or does it not matter if i was to use both displayport outputs to hdmi adaptors for example?
I was thinking of getting two minidp to hdmi adaptors and a 3 hdmi cables and not using the dvi output, would that work?
Yep thats fine, i ran eyefinity with all monitors conected by hdmi, i used one hdmi cable, one dvi to hdmi cable then a active mini dp to dvi adaptor and used another dvi to hdmi on that also
Thank you guys, going to get a an active minidp to dvi then a dvi to hdmi cable, definitely seems easier than hunting down an active minidp to hdmi lead :p
