Eyefinity Setup
18 Oct 2002
Cambridge, UK
Hi,
Right so far I've got 2 games installed:-
COD4
Half Life 2
and I can't get either of them to run in Eyefinity, both games just drop back to the desktop before I even get a look at the "options".
I've setup my 3 x 2407FPWs in the the group shown above, what am I doing wrong ;)
I was hoping it was going to be as "easy" as setting the resolution in the games to 5760 x 1200 but it seems not!
HEADRAT
never used eyefinity so im not 100% sure, but im sure i read you need to download profiles or something. but like i said, i might be, and probably am, wrong.
half life 2 is fine and will work straight off as its as simple as changing to eyefinity on your desktop, running the game then changing res. cod4 will need a widescreen fix or will look wrong but thats a different issue. try setting up the group again from scratch rather than using the saved profile.
CoD doesn't support it without a third party program.
Try Battlefield BC2, best game I've found for it.
It is on nvidia surround :p
OK so it's working, what should I set the FOV in Half Life 2, characters at the edge of the left/right screen don't look right.
HEADRAT
