Ez Wallpaper
sfx
sfx
13 Dec 2004
Hi All,
As some of you may know I made a program a while ago call eWallpaper, well I want to make some changes the other day but it turns out I deleted the source code, doh!
Anyway I have re-coded the whole thing again and re-named it to Ez Wallpaper. I have added a few extra features to it, but here the full details anyway. :)
Features:
  • Load on Windows startup
  • Load minimized to system tray
  • Full control from system tray
  • Save multiple Set Lists
  • Have seletect Set List load by default
  • Set interval between changes
  • Preview wallpaper images
  • Randomize wallpaper rotation
That is about it, if you do use it and you would like something adding or you find a bug please let me know and I will either add the feature if I can or fix the bug. :)
Download: http://www.the-junkyard.org.uk/uploader/bin/EzWallpaper.rar
Cheers,
sfx :)
Not currently no, the icon will always be in the task bar.
I could create the option to hide the icon then you could still bring the application back using hotkeys?
Cheers,
sfx
Cheers,
sfx
I suppose that would be a good idea, being about to assign the hotkeys yourself would be good.
But I don't want to bring it back up, just leave it running in background :)
thanks...
I downloaded the original eWallpaper app a few months ago. I recently got a load of images that I liked for desktop use but couldn't decide which one to use. I then remembered I had eWallpaper somewhere and tried it out. I put it into the folder with all the images and ran the exe. I then right clicked on the icon in the task bar and chose the change image option.
Checked the desktop and it was still the same, tried it again and no change. So I just searched for the app again to see if this problem had occured or to see if I was being a bit dumb. Anyways I find this thread and that you've reprogrammed the app. I tried the link but it is dead. Anyone got it that they could email to me or MSN? Email/MSN in trust etc etc.
Or perhaps the author has another link or can fix the borked link?
Cheers
**And yes, lets get it over with: "Holy thread revival Batman!:eek:"**
