Hi All,
I have been playing about with the new WLM Add-In API and have created a simple bot that will reply with a custom message if your status is not online.
To enable Add-Ins you will need to make a registry change. Add the following:
Close WLM if it is open and re-open it again.
Download the Add-In here: http://www.truz.co.uk/EzBot.zip
Goto WLM option and you should now see the Add-Ins option.
Comments and suggestions welcome.
TrUz
Code:
HKEY_CURRENT_USER\Software\Microsoft\MSNMessenger
Create a new DWORD here called: AddInFeatureEnabled
Set its value to: 1
TrUz
