Hi, just started a co-op with F.E.A.R 3 and we have found that when whichever of us is playing the Fettel character tries to use possession or hits sprint the screen zooms in a bit, but afterwards it never zooms back out. It makes playing pretty impossible, and ruins the experience.
The other character is absolutely fine. We've swapped around to see if the issue is isolated to one installation of Fear, but it happens on both instances.
Just wondering if anyone has experienced this before / heard of it or if it is a known issue? Bit annoying tbh. We are both running Eyefinity setups.
Edit: bugger - seems to be an Eyefinity bug, we changed out of Eyefinity into just one screen and it seems to be running normally. How frustrating...
