- 10 Apr 2004
Right, this is the thread where we will discuss the idea, and add new ideas, etc. You know the idea
Here we go then
Results Page
Here is a basic idea of what it will look like:
http://www.thunder-keep.co.uk/fahstats/test/fahbenchresults.html
Color Scheme etc will be decided later, lets get the layout done first eh?
Blue *** tho
Submission Page
1st stage: Upload benchmark.dat file (PHP Parses the file)
2nd Stange: http://www.thunder-keep.co.uk/fahstats/test/fahbenchsubmit2.html
3rd Stage: http://www.thunder-keep.co.uk/fahstats/test/fahbenchsubmit3.html
(I've selected X2_1 and filled it out as I would do - apart from text boxes)
4th Stage: "Is this info all correct..."
Then Submit! The script should make sure it UPDATES that users entry for that PC and Workunit, not add it again. (Unless specs havent changed)
Users will need to login, this will enable them to edit/delete results if they need to. They should also be allowed to enter all there PC data into a saved file so they dont have to keep adding it.
Maybe a CPU-Z file parser?
Add any ideas/thoughts below!
Conc
Here we go then
Results Page
- CPU Type
- CPU Core
- CPU Speed
- Memory Setup
- Memory Speed
- Memory Size
- Memory Timings
- System
- Client Number (How many clients at a time it runs)
- Min. Time / Frame
- Ave. Time / Frame
- PPD
Blue *** tho
Submission Page
Conc
