- 22 Jun 2006
I'm running the GPU client on my 8800 GTX and I've also set up 2 x console clients on my AMD X2 4800+ using the instructions form the very helpful F@H setup instruction.
My problem is that when the console clients are configured to run at 100% cpu in the Console Client, the GPU client doesnt appear to do any work!
Both cores of the CPU are loaded, each console client is showing 50% cpu usage (or 100% per core), then the GPU client is sat at 0% cpu usage. Proc affinity isnt set on the threads in task manager, I can't set it using the right click - set affinity option in task manager.
I've dropped both console clients to use 75% cpu through the config on the console client and now both consoles and the GPU client are running. However, the GPU client has pulled a 5000 WU instead of the 25000 WUs it has been doing all this week.
is churning out a mind blowing 400 ppd Hardly worth the effort.....
I take it the GPU is throwing everything it has at folding, fair enough, but is there a way to limit the GPU useage to folding to say 90%? So i can still use the PC for other video related tasks.
