@f1 2010's g25 users
29 Sep 2009
Guys does your wheels soft stops works with f1 2010. ?
If your not sure what soft stops are its when the profiler limits the wheels maximum degree of rotation, im using 200 degrees at the mo. My soft stops work outside the game but soons I get on the grid the wheel gets full degree of rotation enabled again :( Is it just me?
So your soft stops are working when you hit the the degree of rotation you dialled into logitech profiler ?
If so any chance you can screen shot all your settings in and out the game for me to try.
Like I say set I've set mine to 200 degrees of rotation and the soft stops work all the way up till the grid and then they just go :( peeing me off as I cant work out why.
