f1 2011 and g27 problem
20 Oct 2010
Scotland, My home.
I have installed f1 2011 again as i couldnt get into it. I am now having problems with force feedback, when i first start a lap i have no force feedback, when i cross over the start line to start a lap my forcefeeback goes crazy.
Everytime i upshift it forces the steering wheel right and it wont stop until i press a button on the wheel. when i speed up there is no feedback, when i turn into a corner there is nothing then if i have oversteer and i turn to correct it, the wheel will force turning right even. No matter what way i correct over steer it will forcefully go right.
Cant seem to find any help on google, can you help ?
Thanks
Marc
I had this an only solved it by downloading the wheel software from the logitech site, reinstalling the wheel and reinstalling the game...
Just to check, have you tried setting the controller type to custom and overriding it to steering wheel in the game?
i have tried that, i have also reverted to the software which i got with the wheel. still no luck!
Yes i have it overriding would this be the cause? its only the wheel rotation.
I asked about the override because for me if its set on the g27 profile in the game its all over the place. I really don't know how mine was sorted but as I said I downloaded the software from logitechs site rather than installing from disc and updating, I also reinstalled the game and it worked so... hope you find a solution soon.
