Fable 2 halp
27 Sep 2004
Having some issues with a certain part in Fable 2.
I'm in a tomb, fairly sure it's named Wraithmarsh - if that helps - on the "love hurts" quest. I've come to a door with a staircase infront of it. Upon walking up the stairs you turn around and above the door, quite far in the distance is a blue orb thing which I presume I must shoot....but nothing reaches it. I've tried going back but can't get through any other doors.
When I came to this point a couple of months ago - yes, I've left it this long because I couldn't get past it :p I had a browse at some walkthroughs but couldn't make much sense of them.
Any help would be good.
Just realised: Above the staircase is a ledge which IF I could get to would probably allow me to shoot the blue thingy. There's a door on the left of some statue which is locked.
Edit:
This is the exact part here:
Walthrough said:
Go through the right side door, destroy the shrubs, stand on the pressure
plate, then go back through the left side. Stand on the pressure plate and
shoot the circle, and voila! Continue through to the circular room and kill
everything inside. To the left there is an orb that you have to shoot, then
shoot it several times as it rests on each statue, and finally, on the door.
Put your Indy suit on and make your way through the firebreathing statues, the
cycle begins at the furthest one then restarts from the entrance statue, so be
careful. When you get to the end, step on the pressure plate and go back.
I'm doing everything it says, but these "pressure plates" aren't budging when I stand on them nor are any doors opening.
