- 29 May 2005
- West London
I done a little test by taking the bottom part of the master socket off and putting my router into the master socket. I ended up syncing 4000kbits higher. (ADSL2+)
I want to now relocate my router next to the master socket and I will need to rewire it as if I put the bottom section on and plug it in there, it syncs 4000kbit lower.
I guess this is because the extensions wired upstairs. What I may do is disconnect the extensions and get a new bottom section so that its cleaner, so that the router will stay next to the master socket.
What is the best route to go?
In terms of networking, I'd have to then make everything completely wireless. I have 3 laptops and 3 machines in the house (3 are in one room). Is it better to go 6 wireless or 3 wired->wireless?
