- 1 Oct 2014
- Northern Ireland
Hi all so after getting my pc set up i then used the discs that came with my mobo to install drivers. All went fine. Then came windows update. After that the wifi totallt shut down and all i can do is use the ethernet to get online. So i went through to restore on the pc and tried getting it back to factory settings. But one the first screen which says please pick country, my mouse or keyboard will not work.
Question is how can i factory reset my pc with this concoction of problems?? Ive tried a lot of other tutorials on resetting the wifi but nothings worked. My mobo is the MSI Z97I Gaming AC mitx.
Cheers
Cheers
