Factory reset PPC iMac G5
11 Oct 2009
Greater London
Have an old PPC iMac G5 in the office at work, and we want to factory reset it. Problem is, the original owner has forgotton his password to the account and has lost the original install discs.
Is there any other way to factory reset the Mac?
You could try resetting the password from single user mode (providing there isn't a firmware password):
Code:
1. Boot into single user mode (press Command-S at power on)
2. Type fsck -fy
3. Type mount -uw /
4. Type launchctl load /System/Library/LaunchDaemons/com.apple.DirectoryServices.plist
5. Type dscl . -passwd /Users/username password, replacing username with the targeted user and password with the desired password.
6.Reboot
Bit of a bump but only just had some free time. The commands didn't work, it can't find the file to load.
However using this command in single user mode allowed me to create another admin account:
Code:
rm /var/db/.applesetupdone
Deleted the old account and now it's sorted.
Now need to work out how to bring it back up to speed...
Single core G5? Never going to be that quick...
OS X likes lots of RAM, at least 1GB is a good idea. TenFourFox should get it browsing the modern internet, all be it a bit slowly.
