Fah GPU, Unstable machine
18 Oct 2002
Temuka, New Zealand
From my fahmon logs I noticed this...
[02:35:38] Completed 96%
[02:37:11] Completed 97%
[02:38:44] Completed 98%
[02:40:16] Completed 99%
[02:41:48] Completed 100%
[02:41:48] Successful run
[02:41:48] DynamicWrapper: Finished Work Unit: sleep=10000
[02:41:58] Reserved 78932 bytes for xtc file; Cosm status=0
[02:41:58] Allocated 78932 bytes for xtc file
[02:41:58] - Reading up to 78932 from "work/wudata_05.xtc": Read 78932
[02:41:58] Read 78932 bytes from xtc file; available packet space=786351532
[02:41:58] xtc file hash check passed.
[02:41:58] Reserved 23472 23472 786351532 bytes for arc file=<work/wudata_05.trr> Cosm status=0
[02:41:58] Allocated 23472 bytes for arc file
[02:41:58] - Reading up to 23472 from "work/wudata_05.trr": Read 23472
[02:41:58] Read 23472 bytes from arc file; available packet space=786328060
[02:41:58] trr file hash check passed.
[02:41:58] Allocated 560 bytes for edr file
[02:41:58] Read bedfile
[02:41:58] edr file hash check passed.
[02:41:58] Allocated 31065 bytes for logfile
[02:41:58] Read logfile
[02:41:58] GuardedRun: success in DynamicWrapper
[02:41:58] GuardedRun: done
[02:41:58] Run: GuardedRun completed.
[02:42:00] - Writing 134541 bytes of core data to disk...
[02:42:00] Done: 134029 -> 111162 (compressed to 82.9 percent)
[02:42:00] ... Done.
[02:42:01] - Shutting down core
[02:42:01]
[02:42:01] Folding@home Core Shutdown: FINISHED_UNIT
[02:42:04] CoreStatus = 64 (100)
[02:42:04] Sending work to server
[02:42:04] Project: 5761 (Run 10, Clone 85, Gen 14)
[02:42:04] + Attempting to send results [December 30 02:42:04 UTC]
[02:42:08] + Results successfully sent
[02:42:08] Thank you for your contribution to Folding@Home.
[02:42:08] + Number of Units Completed: 307
[02:42:12] - Preparing to get new work unit...
[02:42:12] + Attempting to get work packet
[02:42:12] - Connecting to assignment server
[02:42:13] - Successful: assigned to (171.64.65.106).
[02:42:13] + News From Folding@Home: GPU folding beta
[02:42:13] Loaded queue successfully.
[02:42:15] + Closed connections
[02:42:15]
[02:42:15] + Processing work unit
[02:42:15] Core required: FahCore_11.exe
[02:42:15] Core found.
[02:42:15] Working on queue slot 06 [December 30 02:42:15 UTC]
[02:42:15] + Working ...
[02:42:15]
[02:42:15] *------------------------------*
[02:42:15] Folding@Home GPU Core - Beta
[02:42:15] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[02:42:15]
[02:42:15] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[02:42:15] Build host: amoeba
[02:42:15] Board Type: Nvidia
[02:42:15] Core :
[02:42:15] Preparing to commence simulation
[02:42:15] - Assembly optimizations manually forced on.
[02:42:15] - Not checking prior termination.
[02:42:15] - Expanded 68553 -> 357580 (decompressed 521.6 percent)
[02:42:15] Called DecompressByteArray: compressed_data_size=68553 data_size=357580, decompressed_data_size=357580 diff=0
[02:42:15] - Digital signature verified
[02:42:15]
[02:42:15] Project: 5760 (Run 1, Clone 183, Gen 4)
[02:42:15]
[02:42:15] Assembly optimizations on if available.
[02:42:15] Entering M.D.
[02:42:21] Will resume from checkpoint file
[02:42:22] Working on Protein
[02:42:23] Client config found, loading data.
[02:42:23] Resuming from checkpoint
[02:42:23] mdrun_gpu returned
[02:42:23] NANs detected on GPU
[02:42:23]
[02:42:23] Folding@home Core Shutdown: UNSTABLE_MACHINE
[02:42:25] CoreStatus = 7A (122)
[02:42:25] Sending work to server
[02:42:25] Project: 5760 (Run 1, Clone 183, Gen 4)
[02:42:25] - Error: Could not get length of results file work/wuresults_06.dat
[02:42:25] - Error: Could not read unit 06 file. Removing from queue.
[02:42:25] - Preparing to get new work unit...
[02:42:25] + Attempting to get work packet
[02:42:25] - Connecting to assignment server
[02:42:26] - Successful: assigned to (171.64.65.106).
[02:42:26] + News From Folding@Home: GPU folding beta
[02:42:26] Loaded queue successfully.
[02:42:33] + Closed connections
[02:42:38]
[02:42:38] + Processing work unit
[02:42:38] Core required: FahCore_11.exe
[02:42:38] Core found.
[02:42:38] Working on queue slot 07 [December 30 02:42:38 UTC]
[02:42:38] + Working ...
[02:42:38]
[02:42:38] *------------------------------*
[02:42:38] Folding@Home GPU Core - Beta
[02:42:38] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[02:42:38]
[02:42:38] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[02:42:38] Build host: amoeba
[02:42:38] Board Type: Nvidia
[02:42:38] Core :
[02:42:38] Preparing to commence simulation
[02:42:38] - Assembly optimizations manually forced on.
[02:42:38] - Not checking prior termination.
[02:42:38] - Expanded 68553 -> 357580 (decompressed 521.6 percent)
[02:42:38] Called DecompressByteArray: compressed_data_size=68553 data_size=357580, decompressed_data_size=357580 diff=0
[02:42:38] - Digital signature verified
[02:42:38]
[02:42:38] Project: 5760 (Run 1, Clone 183, Gen 4)
[02:42:38]
[02:42:38] Assembly optimizations on if available.
[02:42:38] Entering M.D.
[02:42:45] Working on Protein
[02:42:46] Client config found, loading data.
[02:42:46] Starting GUI Server
[02:44:21] Completed 1%
[02:45:53] Completed 2%
[02:47:25] Completed 3%
[02:48:57] Completed 4%
[02:50:30] Completed 5%
[02:52:02] Completed 6%
[02:53:35] Completed 7%
[02:55:07] Completed 8%
[02:56:40] Completed 9%
[02:58:13] Completed 10%
[02:59:45] Completed 11%
[03:01:19] Completed 12%
[03:02:51] Completed 13%
[03:04:23] Completed 14%
[03:05:56] Completed 15%
[03:07:28] Completed 16%
I've checked them back as far as I have and I've not had another one. Should I just ignore it?
