FAH running too many processes
11 Aug 2003
Taunton, Somerset
My FAH seems to be giving very low PPD.
When I look at the amount of FAH threads that I am running it seems to be running too many I have 2 GPUs and 1 CPU yet task manager shows 4 core 17 processes and 2 core a4 processes. Anyone know whats causing this?
Sounds like everything is doubled up. Maybe F@H didn't shut down properly last time before starting again. Have you tried shutting it down and killing all the processes before starting up again? (Might be easier just to reboot the machine).
Have you checked the work folder to see how many entries there are? There should be 3 directories in it, one for each gpu and one for the cpu. If there are more, you may need to delete the work and start again.
