- 27 Apr 2004
As I mentioned before going, I've been on holiday for the last two weeks. I didn't forget about the FAH Statsig system I had started though (http://forums.overclockers.co.uk/showthread.php?t=17602540 - I would post in there but I think a new thread is justified to avoid confusion with the now unnecessary long explanatory posts).
Link to the builder: http://fahstat.piggott.me.uk
Fixes
Thanks to the GUI you can ignore all of the above though
unless you currently have your signature with a URL from the old version, in which case you should replace 'uid' with 'gen_uid' and 'canvas' with 'gen_canvas' to make it work again.
Ho hum... I think that's everything. The main thing of course is the GUI, and should be relatively self explanatory. Any questions just ask me
Unfortunately one of the things about being on holiday is the lack of an internet connection, and thus I couldn't go Googling for resources. All I had was the PHP Manual so I the layout leaves a little to be desired. The other major thing is the colour options; at present they still take a hexadecimal input (no pop up window with a palette yet
). Aside from that though I'm pretty pleased with it.
For examples of what can be achieved with it, either see the other thread or have a play around with it and see what you can do yourself. My sig at present is an example, albeit a little unimaginative (and no doubt went out of fashion during my holiday).
Sig at time of writing (to avoid confusion if I make a new one):
Note: I have been re-assigning hostnames, domain names and ip addresses (internal and external) today on my network, and so there is a possibility that some people will be temporarily unable to access any fahstat related content due to DNS propagation time.
Fixes
- Averages are now calculated correctly for all users.
- .png and .gif backgrounds now function correctly.
- The GUI has landed!
- gen_qual variable allows setting of image quality (just make sure it doesn't go above the 20kB forum limit!).
- New mode 'team' (i.e. ?mode=team) allows bypassing of the no uid specified error, handy if you want to create a team banner for use on a web page for example. Unfortunately this cannot be set via the GUI so you must create the image as though for a user and then edit the URL changing mode to 'team' instead of 'user'.
- Statistics are now updated every three hours (was daily before).
- uid and canvas variables have been renamed 'gen_uid' and 'gen_canvas'.
- Operating mode no longer 'use' but 'user' instead (i.e. ?mode=user).
unless you currently have your signature with a URL from the old version, in which case you should replace 'uid' with 'gen_uid' and 'canvas' with 'gen_canvas' to make it work again.Ho hum... I think that's everything. The main thing of course is the GUI, and should be relatively self explanatory. Any questions just ask me
). Doesn't do any harm at least anyway, just a few more kB of traffic.
