- 22 Feb 2007
- Oxfordshire
FahMon 2.2.2 is now out!
This is mainly a bugfix release to (hopefully) remove some of the problems people encountered with previous versions.
Here's the complete list of changes:
Hung client notification kicks in when the current frame is > 5x the avg frame time, inactive notification kicks in at 3x the avg.
The major showstopper bug that has been fixed now means your clients won't get stuck in the yellow/orange state for extended periods of time. The states should now work correctly and stay green for active clients.
The alternating background colours in the client list should follow your system colour scheme, although if you change it whilst FahMon is running, the colours won't update until the client list itself is updated.
- Added preliminary detection for hung clients
- Fixed bug which prevented reloading selected client data after being restored from the system tray
- Fixed regression which caused inaccessible clients to report an incorrect state on FahMon launch
- Fixed regression that often caused an incorrect xyz file to be saved when experimental reload system was activated
- Fixed (longstanding) major issue with state detection and timezone conversion which caused clients to have an unknown state when the local timezone has passed 00:00 and the client hasn't.
- Fixed bug which prevented you from running FahMon in "start minimised" mode without "enable tray icon" being set
- Fixed another bug relating to window size not restoring correctly. If the frame is ever detected to be 0x0, default values are used instead
- Client list colour scheme now follows system on both Windows and Linux
- Made more code compatible with newer versions of wxWidgets (Win32)
