So I was using the computer last night when it started making a racket while i was looking inside to try find the source the computer shut off. I gave it 10 mins and turned it on again the racket started and im sure its comming from the D5 on the back of my res. ( im guessing its failed and the lack of flow caused something to overheat and shut off )
so my question's are
1) is there any user repairable parts or should i just opt for a new pump
2) im going to replace my tubing as its 2 years old and my coolant thats 1 year old is there anything to watch out for as i won't be taking off my blocks.
cheers
cheers
