Failed MOT
26 Mar 2010
London
One of the issues where something to do with the wheel were when you brake the wheel jumps forward and pulls back again and this is when you're braking to come to a hold just before you stop completely. This problem is on the front offside. They've told me what they think it is, but I want to see what you lot think it is. Hopefully this is enough for you to understand. :D
Type out exactly what it says on the failure sheet, it might help :p
Edit: Nevermind, I should refresh the page before posting :o
Okay guys, thanks for the help, its a 2005 scenic 1.5dci, any idea how much it will cost to repair? There next door neighbours said to replace the wishbone and labour was 95 quid?
Thanks, just wanted to make sure they weren't screwing me around :D
Is this neighbours doing the work?
The wishbone is about £30 (?) so the rest is labour, but you do need to strip a fair bit off.
I'd perhaps consider changing both of them. A few months down the line you may find your nearside doing the same.
