- 18 Oct 2002
- Aranyaprathet, Thailand
OK, so see if this logic works for you and whether I've correctly identified the likely failed part.
Computer is a water-cooled 2600K, 2x2GB DDR3, Asrock P67-Extreme4, GTX260
Computer boots but does not complete post.
On-board debug code is either 96 - no console output device or 9A - initialising USB.
Graphics card works in another computer.
Working graphics card from another computer produces same errors.
Working graphics card in different PCI-E slot always stops at 9A, never at 96.
Brand new OCZ 750W PSU makes no difference.
No alternate RAM or CPU to test with.
Disconnecting all the USB devices makes no difference.
If motherboard tries to boot, the CPU and RAM must be OK
Problem is not GPU or PSU related.
Motherboard does not recognise the GPU if in the primary PCI-E slot so that is likely to be bust.
Diagnosis: buy a new motherboard.
Anyone disagree?
Anyone disagree?
