Failing motherboard
13 Jun 2008
hi all i have a P5Q deluxe and a core 2 quad 6600 and a gtx1060
the system is in excess of 6 years old
problem i have is every other boot the pc seems to boot with no graphic output
i can toggle the caps lock but no output to the monitor
if i do a bios reset (cmos clear)
the system will boot but all my icons are moved to the left hand side?
question is what do you think is failing
gtx1060 is only a year old the rest of the build is over six years old
please and ideas and many thanks
yes i have
but haven't tried it yet will do at weekend
that was my first thought IE failing graphics card but its under a year old
and the bios reset always brings the system back to life which makes me think it is the chip set ???
