My set up:
Before you ask, There is a tiny kink in the pipe that leads up to the gpu but the photo makes it loo really bad. I can assure you its not that bad, It's the light.
D5 XSPC Pump and res, Double thickness 480 Rad with 4 Thermaltakes at 100% speed
Prime 95 ran for about 4 seconds = 100c/94c/92c Core temps pretty much straight as the program started. I normally get 50-60c during games so I've never noticed it. However with my massive watercooling set up I should be able to handle prime with no problem.
So is my pump failing?
CPU clocked at 3.7ghz @ 1.32v
