Fair usage policys!
22 Jul 2006
BURNLEY TODMORDEN WALSDEN
Recently being tagged by tiscali because I assumed unlimited was unlimited and never checked the emails there and shockingly never read the pages of tos.
I was just wondering if anyone has experiences with switching to business broadband without being a business is it possible? will they check up? would it effect anything like pole tax somehow? :confused:
Otherwise im looking for a good 2mb provider unlimited since this tiscali 8mb never ran half as fast as bt 2mb bb and atm my old ntl dial up ran faster
If you can get Cable (Virgin Media) I would get it. You will be happier on it than ADSL. Tiscali are very bad and the FUP is what makes most people leave. If your staying on ADSL UKFSN are the best ATM bit more expensive though... But good FUP and dont limit your speeds at anytime I think.
UKFSN is a good choice but they, like all Entanet resellers, do limit your speed at peak times.
They don't pick put specific protocols though they just gradually reduce the speed profile of all the connections on an overloaded pipe to avoid the problems that would otherwise occur like packet loss.
It is a good solution that lets them give very generous allowances.
Hay thanks for that sadly cant get cable round here but that UKFSN 2MB Truly unlimited sounds great gunna have another look around but will probley go for that
