Fakefactory cinematic mod 7
10 Aug 2006
Hi, I'm trying to find a decent place to download this from, but so far, the only okish place to download from is filefront, but it is still pretty poor dl rate.
Does anyone know where else I can download this? I'm so eager to have this :D
thanks
The following torrent should be working because I'm seeding it at the moment at 250 k/s
If this link is not allowed on the forums please remove it, it has been posted before so I assume it is okay.
thanks
Looks like a good mod - im getting orange box tomorrow for £18, less when I trade in some junk games/DVD's so i'll get this away on the download box tonight from that torrent, and keep it uploading as best my puny Tesco connection can :p
My box is still seeding it at 250 k/s it's clocked up over 224GB uploaded now, not sure how many seeders there are but I'll leave it running.
What's cinematic mod? It's for HL2 isn't it?
What would be the recommended spec to play it? I have a c2d e6300, 2gb ram, 256mb 7600gs (think that may let it down a little).
its recommended for cards with more than 256MB of ram i think. lemme dig-out the readme...
Readme_CM7.txt said:
FAKEFACTORY CINEMATIC MOD V7 FULL
Build 7.0HDR (RC1)
for Half-Life 2 / Half-Life 2: Episode One / Half-Life 2: Episode Two
TO PLAY THIS MOD, YOU MUST OWN HALF-LIFE 2 / EPISODE ONE / EPISODE TWO FULLY
INSTALLED AND UNLOCKED!
Remember to activate "High Quality" graphic settings in the options dialog.
PURPOSE OF THIS MOD:
- Raise the quite outdated graphical appearance to a state-of-the-art level
- Give the HL2 trilogy a more stressed, darker and minatory look
- Complement the atmosphere with a emotional cinematic music soundtrack, that fits the action on the screen
- Replace the low-resolution textures with high resolution counterparts and more detailed environments (hires melones!)
- Complement the storyline with the unused content from the original games
- Refresh the look and feel with optional new HD models
- Add more replay-value
CHANGES SINCE CM 4/5/6:
- The first FINAL Alyx Hires models
- Reworked sounds and music
- Almost all textures reworked or updated
- Added Hires-Detail-Overlays
- Added HDR to HL2 (See below)
- Fixed two potential crash-bugs
- One pack for all episodes
HDR for HL2
Not all HL2 maps are true HDR, because not all sources are available. For all
other maps i used a technique, that i call "Entity injection". Technically i've
used clientcommand entities and tonemapcontrollers to achieve a hdr-like type of
blooming on those maps. This type of bloom is much more realistic than the old
bloom mini-mod, because the effect is controllable inside the map for different
settings at certain locations. You can call it HDR V0.5 or Bloom V2. Its some
kind of super-ehanced bloom that gives a near-HDR look on the old HL2 maps.
Some of the map-settings aren't final (i'm still at the fine-tuning phase)
HDR AND THE OLD VALVE MODELS:
With HDR enabled in HL2 some of the faces of the OLD ORIGINAL VALVE CIVILIAN
models are appearing too bright sometimes. This little glitch will be fixed
with the next version. The Hires models faces are looking right.
CHARACTER PIMPER:
By default most of the optional HD-models are disabled. You can use the
"Character Pimper" to switch between HD models and original VALVE models.
The Alyx HD-model was built from scratch, all other models are based on
massive modified POSER7 models and compiled with a rewritten studiocompiler,
that is allowing a much higher polycount than VALVE's original compiler. The
facial animations were build with 3DS MAX and exported with Cannonfodders
VTA -exporter.
USING OLD CM6.x Alyx Hires models in this version
The V7 Alyx models are completely reworked with enhanced skeletton and facial
animations. The older CM6 models are not longer used. If you want the older
models from your CM6 installation, make a copy of the CM6-Characterpimper
"repository" folder and the CM6 "hl2\materials\models\Adriana" folder before you
uninstall it.
After installation of CM7 is completed, you can copy the old content to the V7
directory, BUT DON'T OVERWRITE V7 FILES! I strongly recommend to use the new CM7
models. They are optimized for the Orangebox engine. I will release recompiled
V6 models as a update-patch in the near future.
SOUND DROPS OR CRACKLING:
If sound crackles occures, you can fix this by setting the snd_mixahead value in
the autoexec's of CM's subdirectories. You will find the autoexec.cfg in the
FAKEFACTORY_CM\hl2\cfg
FAKEFACTORY_CMEP1\ep1\cfg
FAKEFACTORY_CMEP2\ep2\cfg
directories. Try different value like snd_mixahead "0.2" or snd_mixahead "0.4"
for increasing the buffered time of soundsamples. This will fix crackling or
dropouts, but can lead to slightly asynchronous or delayed sounds.
MICROSTUTTER AND HEAPSIZE
If you encounter microstuttering ingame (animations), try the heapsize command.
Add -heapsize {bytes} to the shortcuts, i.e.:
Shortcut: Cinematic Mod EP2
Target: ....launcher.exe" -heapsize 512000.
But NEVER set the heapsize above [YOUR INSTALLE RAM / 3] or 512MB
SETUP.EXE AND VIRUS-WARNING
Setup uses a tool called SetACL for setting write permissions to the mods
screenshots / cfg / SAVE directories. Some antivirus software could warn about
possible malware. This is a false positive.
TECHNICAL INFO:
This mod's binaries are modified for memory allocation beyond 2 GB. To
prevent STEAM from overwriting this binaries with its own copies on each start,
the mod ist using a little launcher, that reroutes STEAM's original binaries
to >NIL.
Start this mod only with the shortcuts in your start menu (that were
created during installation)!
HARDWARE REQUIREMENTS:
- DX9 capable graphics hardware with minimum 256 MB VRAM. (512 MB recommended)
- 3 GB RAM (4 GB recommended)
SOFTWARE REQUIREMENTS:
- Fully installed STEAM Client; You can't start the mod without STEAM running.
- Fully installed and unlocked HL2 / EP1 / EP2; Make shure, you have started those games in the past.
32 BIT WARNING:
This mod was developed and tested on 64 Bit Windows. It is NOT supported on
32 Bit Windows, because of the limited Userspace with 32 Bit systems. You
can try it on 32 Bit, but prepare for crashes.
On some 32 Bit systems it is possible to overcome this limitation with some
boot.ini switches for raising the userspace limit. I'm not going into
detail here, because those tweaks are dangerous and should only be done by
people, who are knowing exactly, what they do.
ADDENTUM FOR VERSION 7:
V7 of this mod uses much more Hires textures than the previous versions. This
means: The engine has to cache a peak-value of >2GB texturedata at runtime. It's
almost impossible to play this mod crash-free on 32 Bit systems without lowering
the graphics settings.
USED SOFTWARE FOR THIS MOD:
Adobe Photoshop CS2
3DS MAX 8
E-Frontier Poser 7
Microsoft C++ Visual Studio 2005
Powerbasic 8
VALVE Source SDK
Sony Soundforge 7
Sony Vegas 7
Crazy Bump 5
Cannonfodders SDK tools
entspy
vmex
Autoplay Mediastudio Pro
Setup Factory
USED TEXTURE RESOURCES:
Majang.com
3d.sk
Dosch
environmenttextures.com
Own photos
USED MODEL RESOURCES:
contentparadise.com
efrontier.com
daz3d.com
DONATIONS:
Development of the Cinematic Mod has taken 3 years of my life, a vast amount of
coffee and 14000+ dollars for software and resources. It will stay free for
all, but you are welcome to donate a free amount for further development via paypal.
If you want to donate, please click the following link. You can choose the
amount of your donation yourself
https://www.paypal.com/cgi-bin/webs...ode=USD&lc=US&bn=PP-DonationsBF&charset=UTF-8
I d/l this a while back (not from this torrent though) and I get an error complaining about the materials.zip being corrupt. The game plays ok but Alyx and other bits are just in bright purple!
Can I download just this zip or folder from somewhere?
