fakefactory cinematic mod help plz
12 Feb 2004
Sheffield
hiho
So i went and installed HL2 today :) ity's the first time i've played it since the first week it came out. sry i find single player games dull generally, so i had no wish to play though it again. however i wanted to test out Fakefactory's MOD.
yeah i'm being stupid here, but please tell me where the thing is supposed to be installed!!
Instructions says put the cinematic folder in here:
<PATH TO YOUR STEAM-INSTALLATION>/SteamApps/<YOUR USERNAME>/SourceMods/
however, my directory sturctre is not the same as that, my /SteamApps/username/ folder doesnt contain a folder called SourceMods. i made one and put the folder in there but i dont think, it changed anything.
the only source mods folder is here:
C:\Program Files\Valve\Steam\SteamApps\SourceMods
and i have a:
C:\Program Files\Valve\Steam\SteamApps\username
but no
C:\Program Files\Valve\Steam\SteamApps\username\SourceMods
i tried the mod folder in the Source Mods folder that i do have, but that didnt work either :/
is there something else i have to do to activate the mod or something?
:confused: ty for any help
or am i expecting too much from this mod? is there actually a big difference?
i havent got the MOD yet so cant help, but can i ask you which version you are trying ? as fileplanet is showing 1181mb and 486mb ver .232
which is correct
All mods should be extracted to:
...\Steam\SteamApps\SourceMods\<modname>
So if it has not extracted to a new folder in the SourceMods folder, try that.
You have to restart Steam after you have extracted the files.
which is correct
FAKEFACTORY CINEMATIC MOD V3 final
Complete Non-Override version
Patchlevel: 3.01
ok thanks
As said drop it in here
I downloaded it the sarvo and its woirking fine :)
got it working, thanks guys :cool:
however the sound is slightly out of sync :o
i googled it and someone mentioned it on the comments thing on fileplanet, but there was no answers. anyone else have sound problem with it?
