Faking DOF in photoshop?
7 May 2007
Anyone got any tips for this? Didn't know how to do it in max so I ended up just using blur filter in a feathered selection area in ps... not too sure about the outcome though...comments and suggestions appreciated!
P.S- DOF= depth of field
That looks absolutely fine to me. That's the way I'd do it - perhaps using the 'Lens Blur' filter instead of Gaussian.
You could try a different method for the graduated blur to fit the perspective - no idea how successful this would be though! Create a duplicate layer with lens blur at the maximum level you want it, and then place a layer mask over the top of it. Apply a black/white radial gradient to try and get the blur to be masked more appropriate to the perspective.
Found it, http://recedinghairline.co.uk/tutorials/fakemodel/
My attempt:
