- 6 Sep 2016
So you you are 5000 feet and you jump out of a plane. You don't have a parachute but you have portal gun.
What do you do?
What do you do?
Splat into the ground as portal guns don’t exist.HTH.So you you are 5000 feet and you jump out of a plane. You don't have a parachute but you have portal gun.
What do you do?
This pretty much, change your vertical velocity into a horizontal one, with a little tilt upwards and use mavity to slow yourself down again.Fire portal horizontally?
Air friction `should` slow you down,gradually fire prtals lower and lower......maybe
Not if you managed to slow yourself down as we said you won`tYou'll die whatever you do. Unless there was a huge cushioned area to land in then no matter what you'll die.
Entry portal below, exit portal angled 85 degrees upwards. This will cause you to to travel in an upwards parabola gradually reducing speed.
New entry portal at the top of the arc, exit portal on the ground, with 0 momentum
Too much maths in the head...Portal into above Trump, should be a soft landing.
But if you shoot a portal horizontally it won't have anything to attach to so no portal?
And also the BESt landing
