Are you absolutely certain no other mods [that don't involve just replacing textures] are installed, or have previously been installed during this character's game?
Could be anything then, including a bad install of that hud mod
Not much to go on.
Before reinstalling [Steam file check etc] which you may already have done, I'd try starting a new character temporarily to see if the same thing happens. Make sure you have a solid save of your existing one first - not just quicksave/auto.
The solution would be to work out what's with your PC thats upsetting it! The game is worth persevering with. Were it not for the short main quest and the hopeless default vanilla game balance issues I'd rate it as a better rpg than Skyrim.
My guess would be background apps. Any time of activity from my anti virus will CTD it and I cant currently alt tab with my Fallout 3 steam install. Couldnt be bothered to start regression testing options in ATI catalyst and so on as the game loads and exits so fast anyway.
