Fallout 3 help -spoiler-
27 Oct 2005
Netherlands
Hello,
I'm at the start of fallout, where you had to go to a radio station then the guy tells you to fix some dish or whatever for him to increase the range of the radio station so he gives you info about your dad... I erm, killed the guy though and the quest changed to ''the search continues'' with no hints where to search for my dad, where can I continue to look for dad :p ?
That aside, can anyone tell me how to move faster ? I'm tired of this very slow running, are there vehicles ingame or can I sprint somehow ?
Hello,
head to rivet city to continue your search, its at the southern end of the island the radio station is on.
you can use fast travel aswell to places you have discovered :)
also where up to the same part apart from i never killed 3dog :P you have to go to some aircraft carrier that has been made into a city edit: thats it rivet city
Can any one help me.
I need to talk to the Lady (cant remember name) that can give the word so I can get trained to use the power armour.
I cant find her anywhere in the radio station.
Thanks, rivet city appears to be very far away :(.
Can anyone help with with this then:
Where can I buy some bloody ammo except in megaton at the supplies shop ? I keep buying out her whole stock of ammo and I keep running out of ammo, especially need ammo for the assault rifle, 10mm gun, the sniper and also the hunting rifle... And I have enough caps to buy at least 500 bullets ( have 1000+ caps)...
The shop in the place where the Vampires hang out has lots of ammo.
Vampires :confused:?
Have you been doing the missions in Megaton? One of them from a girl in the bar leads you to a village called Arefu which then leads you to vampires. Good perk from that one, get a new ability from the vampires. Similar to the perk you get for doing the fireant quest in Greyditch
Would like to play without cheats though, where's this place with lots of vampires though ?
EDIT: Ah, nope I haven't done any quests from the bar.
And I'm still doing the fireants mission, have no idea where they are coming from yet but did the bit already where the boys dad got killed and u have to tell im...
