- 27 Jul 2006
- Huddersfield
Just bought this to try a hand at the fallout games again, however ive hit a block.
I cant install Fallout 1
It starts the install program and then crashes saying "The current version of the application could not be determined. The setup will now terminate"
someone please help.
Ive found somewhere that tells you how to manualy install but my disk seems to be set differently, has different cab and data files.
Thanks
Zero
Thanks
Zero
Up until that point, everything had been OK. Basically if I tried to take the lift down to (what I think is) the final area of the game, it would always crash.
