False Readings or ?
25 Nov 2011
Liverpool
are these temps normal for push/pull h60 ? or are they false readings.
I know there idle temps but just wondering :)
Not sure for the h60, but I've had similar readings with other amd chips, the most extreme case being the fx4100 in my dad's computer, supposedly 8C under load. Could it be an issue with core temp and amd hardware. On a more helpful note, try checking with CPUID hardware monitor and AOD, both of which have temperature monitoring.
