- 28 Jul 2007
So after coming back from uni, some how my family have runined the home PC. I am going to reinstall windows, but first I have a couple of questions.
The PC currently only has 512mb of 3200 RAM. I have 1.5Gb of spare RAM laying about, but it is only 2700. So my first question is, can you mix these types of RAM, and if so, would it be worth it, or better just to stick to 512mb of 3200.
Secondly, i understand that you need to install the motherboard drivers after installing windpows, unfortunately the discs that came with the pc, presumably with the drivers are nowhere to be found. Is there any easy way to find out what motherboard drivers I will need to be installing. Its a pre built dell PC whihc is about 2.5 years old.
And lastly is there anything else that I need to be aware of. It doesnt have a gfx card so no drivers need there. But are there any other drivers that I will need to be installing?
Thanks for your time.
