Hi
I currently have the three fans that came with the EK kit I bought set up to exhaust air out of my case as below:
As I am going to be watercooling the two 7950's I assume that it will not be a problem for me to turn the fans around to blow cold air over the radiator rather than pull warm air through it? This surely will help lower temps...
I am also going to change the fans for something quieter with more perfomance. What would you recommend? I see the gentle typhoons have good reviews also the Phobya nano g.... to be fair I have no idea what to go for
Any advice as always appreciated
Although if you don't plan on putting them on the fan controller (don't see why you wouldn't though), then go with the 1250/1450RPM versions, as I think the EK radiators perform best at these speeds.
