Seeking FAN advice, with case: CM NR200P and MB: Gigabyte B550i AORUS PRO AX. The mother board has the following fan headers; CPU_FAN, SYS_FAN 1 and SYS_FAN 2.
Will I need a fan hub? To operate 6 fans and CPU cooler.
Or just fan splitters?
Current setup - NZXT X63 (3 pin connector from cooler) plugged into CPU_FAN,
2 fans on 280mm radiator plugged into SYS_FAN2 (using the provided fan power ext cable) as intake. I also have the 2x stock CM 120 fans in the top as exhaust.
however, I have 4x Artic P12 (SLIM) fans arriving tomorrow. The intention is to have 2 at bottom (intake) and 2 at top (exhaust).
Any advice on how people would wire the fans for this setup would be much appreciated. This is only my second build and the wiring of the fans is my only concern.
Many Thanks STE
Many Thanks STE
