- 12 May 2005
- Cambridge, or somewhere else in the world
Hi,
I'm about to upgrade the cooling of my akasa eclipe case. Currently I've two akasa amber 12cm fans 1 front, 1 back, which are beginning to show their age. Even though I've lowered the volts they're still a bit noisy for my taste - my system is cooled by a Zalman Restorator so the usual noise suspects are pretty much dealt with for minimising noise.
I'm thinking of getting a Scyth Kama-bay cooler and three Noctua fans (2 for the front one for the exhaust).
Now, what speed? Will 800rpm be enough or should I go with my first inclination and go with the 1200rpm version? Or 2x800 for the front and 1x1200 for the rear, or 2x1200 for the front and 1x800 for the rear to have +ve air pressure to reduce dust?
Many thanks
tophee
Many thanks
tophee
haha
.... Honest!
