Fan Advice
8 Sep 2014
So i am doing a build in the SMA8 from caselabs but i just wanted some advice on what fans to use (Aesthetics only). Now the choice is either the Corsair AF series with the Red rings or the Corsair ML series with the black or colored corners. Just wanted to know which ones do you think look nicer?
I have two pictures below that show what they look like:
This is a build by crinkleshoes (on this forum), he is the only one I know who is using the ML fans on the net. Mine will be Black for now but once corsair release the changeable corners i will be getting red ones. The fans themselves are the non led pros that are completely black.
This one is by jayztwocents, now he is using AF140's but forget that we are only focusing on the looks here. I would have red rings.
So fans with the rings? or the fans with the rubber corners? What would you choose if you had a choice?
It would be nice if i could get some replies so i can make my decision ASAP.
Thanks
