Fan Arrangements (Drop 5-10c in CPU temps)
9 Dec 2006
@ManCave
So i like to experiment with Fan arrangements & every case i use i test every Fan arrangement i can
Recently changed to a Fractel Design R5 Xl R2
Spec: 5930K 64GB ram ASUS WS-E 980 Ref edition
Tested using
Handbrake 1080p bluray transcode (cpu 100%) for 30 Mins.
Ambient: Used My Air Con to get my Cabin at the same ambient on both tests (22c)
Before
in
2 140mm Noctua Fans Air edition ( front) min 100rpm- max rpm 800rpm
1 140mm Noctua Fan PF (Side) 100rpm- max rpm 800rpm
out:
1 Noctua 140mm AF Back 100rpm- max rpm 800rpm
CPU
1 Noctua Cooler 100rpm- max rpm 1000rpm
CPU highest temp 62c At 100% load average 60c
in games: over watch over 8 hours
CPU highest temp 57c At 100% load average 59c
After
In:
1 140mm Noctua Fans Air edition (bottom) min 100rpm- max rpm 800rpm
1 140mm Noctua Fans Air edition (side) min 100rpm- max rpm 800rpm
out:
1 140mm Noctua Fans Air edition (top) min 100rpm- max rpm 800rpm
CPU highest temp 57c At 100% load average 55c
in games: in games: over watch over 8 hours
CPU highest temp 55c At 100% load average 48c
