- 28 Jan 2005
- Southport
Hi all
the other night I posted about my RPM dropping when I have my electrics on Lights, radio, heated screen and blower enough to make the car shake a little. So i took it to a garage I know and they tested the battery from idle, 2000Rpm with electrics on etc and it was OK so he said the fan belt needed changing as it was quite old and slipping a little.
Now I have changed it and around 3000Rpm there is quite a loud whistling sound can anyone tell me what that is?
Also it hasn’t seemed to sort the RPM dropping problem out any other suggestions?
Thanks
Thanks
