Fan buggered
14 Sep 2008
Peterborough
One of my 1070 Strix fans has started making a lot of noise - it's wobbling so it's catching on the heatsink. I've tried fiddling with it but as soon as it starts spinning you can visibly see it's unbalanced. Anyone had this issue? Dealing with ASUS warranty is ...... pfff... well y'all know how bad it is. I've looked at the fan and it doesn't appear to be damaged in any way :/
rma or take off the shroud and jerry rig some fans onto the heatsink
or type in strix fan on your favourite auction site, looks like you can replace just the fan
Nah mate. It's spinning consistently it's just not spinning level - so when the blades wobble down it catches on the edge of the heatsink so it's almost making a chirping noise (because of the fan speed and how lightly it's hitting). It's annoying as heck.
It'll only get worse and fan blade will shatter. I'd stop using it and contact Asus support to RMA it.
if your lucky the fan has moved on its spindle ie tilted and might be lifted off or put back onto the cooler straight, but its much more like some internal part has failed, dissasembly will tell you which but theres the warranty question if you do that
Unfortunately I have. And be very careful because the Asus fan blades are very brittle. If the fan is definitely faulty then I would go along the idea that you need Asus to repair it. I have tried in the past to source Asus fans and it's impossible ~ unless you get exactly the same item you can end up with something that looks good but doesn't perform at all well. The only good way to get one is find dead card and steal it's fans!
