fan chart?
Airflow (CFM) Noise (dBA) Max speed (RPM)
DustPROOF 92mm 28.0 22.0 1600
NF‑B9‑1600 37.8 17.6 1600
Coolink SWiF‑922 35.5 22.0 1850
Zaward Clear 92mm 29.7 18.3 1500
Zaward Black 92mm 29.7 18.3 1500
Kaze White 92mm 62.6 34.1 2800
Kaze Jyu SLIM 27.6 29.2 2000
Zalman ZM‑F2 53.9 36.0 3000
Xilence Red Wing 92 36.0 19.0 1500
Something like that? ;)
what's a good cpu temp monitor? I think I'll try running it without a fan and see what it's like.
And what temp should a x2 4200+ (939) be at?
If you want really quiet fans consider running them at 7v or 5v.
Just a quick question, why do you need 10db? Hard drives are normally louder than this most of the time...
yes the 7 volt trick does that and temp found this with google ;
AMD CPU Assistant has both my cores idling at 50 degrees celius (with sides of case off)-65 degrees celius(with sides of case on)
It is winter here so max air temp is 20-25degrees
ps http://forums.amd.com/forum/messageview.cfm?catid=21&threadid=96558 at the temp at 50 degress is is high is the second post on that forum
Well I'm using a load of Noctua 120mm 800rpm which are around 8db I believe. I want to upgrade mobo and cpu soon, so I don't want to fork out on anything to costly. Probably best to see if I can just get away with no fan. It's a nice roomy case with good air flow. and one of those big tall heat sinks.
Also HDD aren't constant and aren't such an annoying hum.
First of all, take a gander at SPCR if you haven't already.
Also, take a look at the Thermalright HR-01 Plus, it's designed to run without a fan, but performs better with even the slightest of airflow.
