fan choice
8 Apr 2008
i seem to be peppering these forums a lot recently but after a bit more advice.
firstly im after recommendations for 2 x 140mm exhaust fans. Near silence would be the aim so Noiseblockers, or something PWM that can go as quiet.
that would leave my system as 2 x noctua in, volted down to 5v ultra quiet, one noctua 120mm exhaust + the two 140 mm to buy.
would consider going pwm for the two intakes too, so feel free to recommend on those too.
thx
I bought 2 140mm corsair af140 recently, very quiet and they seem to be performing really well, i dont know about the fans you've mentioned myself but the corsair fans did a top notch job.
I popped in 3 x Alpenfohn 140mm into my 540R case and they are lovely.
The noisiest thing in my rig is the dvd drive!
which af fans are people buying the low noise versions ?
