Hey guys recently have been trying to push my overclock a little further than 3.6 GHz aiming for around the 4 GHz mark. Current prime load temps are in the low 50's. I tried pushing it to 3.8Ghz, with the side panel off max temp was 59C/60C as soon as i put the side panel back on temps where up to around 63C/64C which is over the 62C max, with no headroom to try and get 4Ghz. So I was wondering if there was anything I can do to my current fan setup, or is my CPU cooler just not up to the job?
The case has an extra 120/140 fan bay at the top currently has padding over it, same for the side of the case. Would moving one of my front 120mm intakes and adding it on the CPU heatsink in a push pull configuration help the temps much?
The case fans are Fractal 140mm 600rpm and 120mm 1000rpm with an Akasa viper on the cooler.
So would moving the fans in another configuration improve the temps basically?
